Dooh, my hall sensors are firing very well. I had my father around with his Osciliscope and all my hall sensors are triggering.
Problems i have with it atm, The controller is set for the 18Fet rather then the 12Fet flash settings to stop the cut out, it cured the cut out problem of really hard throttle acceleration but seems to be causing a limit to the voltage i can supply, its there some other setting i need to change?
1) Currently my controller does not want to push the motor past 5.6V full throttle on either setting of my 1,2,3 switch ends up with the controller only outputting 5.6V to the motor.
2) I have checked all 36 combinations of halls and phase wires(listening to some good music) and found only 2 setups where the motor ran good out of each lot of test, 1 back and 1 forwards, both ran equally well so i would assume that means my halls are in a ok position, but i cant get my motor to spin over 6V now so its amp draw is 2.7ish which is still way too high
3) Very high no load amp draw when compared to others running the same motor. its almost as high as one of the 7KW motors....with skirt bearings.
4) On the Oscilloscope my halls are outputting only a pulse rather then appearing as a square trigger, could just be the oscilloscope measuring differently
5) My halls are roughly 99% accurate in their positions, 1mm out over a 166mm diameter can.
6) My Throttle does not seem to activate the motor till i have moved the throttle about 1/3, starts the motor by itself every time now that i have placed the Hall ring better. The signal volts from the throttle i don't get :? On the positive wire it reads a perfect 5V with the voltmeter i have, black wire to the battery negative and the red onto the red wire from the throttle. But when i test the buth throttle output wire and the negative wire i get nothing when the throttle is off and then it only goes up to like 28mV, millivolts.....wtf. I assumed it should have read something from 1.4V-4V or so. Can someone tell me how to test the throttle properly. This is tested with a cheap range self adjusting voltmeter.
Anyone have any suggestions about what i have done wrong?
Ohh and the glass table is still all good, no scratches on it either. Will need to go wood as glass makes too much noise when you drop heavy metal things on it
