Rassy
For the last couple of hundred miles my 171B NuVinci CVT (Developers Kit) has been making a rattleing noise in the higher gears. It sounds sort of like a jack-hammer except not so loud. The noise is there only under power, motor or pedal, and goes away when coasting. The noise can even be heard when running in the shop with the wheel up. Everything is working properly, except for the noise.
Since I had another NuVinci CVT on the shelf I swapped the noisy one out for the new one. Noise gone, as expected. The only change is the NuVinci hub, i.e., the same wheel and spokes, track cog, chain, electronics, actuator, etc. were used.
Now my question. What happened to my original NuVinci CVT? It probably had over 1000 miles on it. The 500 Watt electric assist mid drive hub tops out just over 1000 Watts draw from the battery. Could it be internal damage because I use a track cog instead of an external freewheel? (This means the internal NuVinci frequently freewheels.)
I would like to hear about any similar problems and causes. Even though there was no warranty on the developer kits, I am going to see what Fallbrook might think caused the problem.
Thanks,
Thanks,
