LI-ghtcycle,
"The closest I see for the simulator is 200 kg (440 lbs) so in the ball-park."
Notice that in any of the boxes, except for motor, you can scroll to the bottom and select "custom." You can get exactly what you want for weight, etc.
"If I can figure a way to see what the "simulated" gearing would be with both my initial reduction, and the range of the NuVinci, (total of 3.5 to 1)"
OK. A MXUS 4503, 450 pounds, 26" wheel, semi-recumbent, 16s, 20 Ah Ping pack (close enough for low load calculation), 60 amp controller, 1% grade (I find that 1% gives a good match to real world "flat" conditions) does 37.3 mph. I doubt you will want to go any faster on your rig. With a 350% total gear range, if you gear the motor 1.75:1 to the NuVinci, say 16T motor, 28T gearbox, then highest speed is ~37 mph(26" wheel), and lowest is ~7 mph (7.4" wheel). Up a 10% grade that 7.4" gear gets very good efficiency (87.4%), but only ~6 mph. Highest gear (26") get you up at 13.8 mph and 67.7% efficiency. If you play around with your highest gear you find that you can get to 14.4 mph with a 32" wheel, but going bigger an inch at a time gets no more speed, until you actually start to loss speed at some point. If you look at battery volts, and motor efficiency, you will see that the battery has started to sag, and amps are going up as volts are going down, and heat is going up. Going to a custom pack setting, you find that adding Ah or voltage, or better chemistry (lower ohms) to the battery greatly improves performance.
For instance, going to 54.4 volt nominal, .029 ohm, 53 Ah usable, like my Leaf pack, gets your rig up there at 20 mph, 85.9% efficiency, 12.6" gear. And your lowest gear, 7.4" gets you up a 20% grade at the same efficiency, and 11.6 mph. And your highest gear, 26", gets you ~41 mph on the flat.
