I merged them for you; I can delete the duplicate OP if you like, too.
Regarding using the 4.5V adapter, you could install two diodes out of an old PC PSU's AC-input section in series to the + line on the wallwart's output. THat'd take it down about 1.4V, making it close enough to the original adapter's voltage to probably work normally. The 100mA vs 80mA capability is probably fine, in that the internal charger in the trimmer will likely only pull <80mA regardless of what the adapter is capable of.
The only potential issue I can think of is that the trimmer may not put enough of a load on the new adapter, and so it's voltage may be higher than expected, if it is the old transformer-diodes-capacitor type, rather than a switching type. The former is usually notably heavier than the latter, so tends to be easy to tell them apart.
You coudl test beforehand by using a resistor across the new adapter's output to present the same load the trimmer will. Add the series diodes first, then the resistor will need to be R = E / I, (ohms = V / A). So 3.6 / 0.08, or 45 ohm. Paralleling four 180 ohm resistors would be perfect. Two 100 ohm resistors will be very close if you have no 180s. The resistors might be found within the PC PSU, too.
Once the resistors are across it, clip or hold your DC Volt meter probes on the resistor leads, then plug in the adapter. It should read 3.6V, if it does not and reads significantly higher, you'll need to add a bit more load to it. Once you find the right load to make it read 3.6V, you could then leave just that load on there, then remove the 45ohm load, and hook it up to the trimmer. Verify voltage again, and if it's ok, you're all set.
