NeilP
1 GW
If my mate that painted it had been happy with the original built in light system on the lathe, I'd not be doing this
We bought it together 3 years ago.
Saddle gearbox was shagged...so we stripped it and rebuilt it...But Dave, wanted to make it look shiny too...so he started stripping irreklant bit to paint it up..f..ing pointless to my mind but he wanted to do it..so we never got around to finishing it..it has been sitting under a cover for three years.
Then the other day we got keen again...and he now decides that he did not like the basie original 50 VAC built in incandescent lighting unit..ok so it is a bit naff and yellow light but at least it worked.
So i thought ..lets just replace the 415 volt t-50 VAC transformer with one that puts out 240 instead..then run everything off it...
Have been looking on RS components I might now get a 420 to 2300 volt transformer.
gives options on the input side to 'tune ' the output voltage
got this from the maker of the DRO
Thank you for your email. The specification for the Topaz operating voltage is 115 V AC or 230 V AC, + / - 15 %. This would make the maximum recommended input voltage 264.5 V AC. Your transformer output of 267 V AC is technically outside of the range of the specification. We would not envisage problems using your supply but we cannot he held liable for any damage or injury that may result from connecting to and using the Topaz from the machine supply.
