Thanks for the replies everyone! I currently can not invest in a more quality bike so it looks like I will just not go as fast for now.
mvly said:
Wow nice clean build. I see a chain lock. Do you actually lock this up?
When I built my ebike I was going for stealth. If I had known more about battery technology at the time I would have invested in some Lipo's to make it even stealthier. I lock my bike up all the time. It's an On Guard chain and the guy who sold it to me at the store (around $48 with tax) said you need a hydraulic cutter to get through it, so that's good enough for me
mvly said:
It would be even better if you go 96V. But definitely check the limits of your controller. However you can always get a Lyen's controller (PM him) and I am sure he will sell you a decent controller that can handle up to 100V.
Apparantly the 48V GM controllers can't go past 60V so I will definitely be replacing the controller. I hear good things about the Lyen controllers. What advantage would I have with going with this controller vs. the one that wesnewell posted:
wesnewell said:
Buy this controller and 24s lipo pack. Charge to 100V. hang on when you hit the throttle.
http://www.dhgate.com/72v-1500w-brushless-speed-controller-for/p-ff808081283845f5012848d41bf455fb.html
I like the thought of buying this controller as it is inexpensive, but can someone give me reasons as to why the Lyen might be a better investment?
amberwolf said:
Next, I'd make sure your suspension can handle the road conditions at those speeds. If you have all smooth roads with no debris and no potholes/etc, it won't matter, but it makes a huge difference hitting a 1" deep pothole or chunk of asphalt/etc. at 20MPH and 40MPH.
At one it's just annoying if the suspension bottoms out or doesn't respond fast enough, at the other it could cause loss of control and a crash.
Just a side question: What causes it to take so much time per km? If it is time waiting for other traffic to be out of the way, or waiting at traffic controls, then having a faster bike isn't really going to change things much, if at all.
If it is time actually riding, then it seems like the bike you have is already fast enough to do the whole 5km in not much more than 10min., if that.
The roads I take are actually quite smooth and I travel them enough to know exactly where any holes are, so the suspension problem would not be too much of an issue. If I go anywhere else then I just wouldn't travel as fast. As for why it takes so much time per km, it's because the main road that goes from my house connects many major highways here as well as major streets, all within a few km of each other. Add to that the fact that I live in Canada's technology capital where there are lots of business buildings open all the time and the fact that there is major construction being done blocking off 1 lane in each direction for the next 4 years, traffic almost comes to a halt. I actually walked down the sidewalk here once along the road and stayed with traffic for almost 2 kilometers, until I passed the area where the highway entrance is. I usually take side roads to get to where I need so that increases my distance to travel and I need a good top speed to make up for the lost time. Also, sometimes I just need to take the busy road and the speed limit is 70 (60 now since it's under construction) and keeping up with the traffic would be a lot safer in my opinion as the drivers are very inattentive on this road. But even when it's packed full of traffic, I can easily zip by in the far right lane since there is a lot of space between the curb and cars there
dogman said:
What is your top speed now?
About 45km/h on the flat, tucked, no wind and allowed to speed up to that speed over about 20 seconds. Ontario loves putting stop signs everywhere instead of using yield signs or roundabouts, so I almost never get to accelerate to such a speed anyway.
dogman said:
You shoud be able to see at least 55-60 kph with a 1500 watt controller like the one mentioned above. At 1500 watts, it's pretty low amps so you should be able to stack a 24v battery with your current one and get away with it. I see nothing wrong with upgrading your bike to 72v with a low amp controller. That might get you into 55 kph. ( about 35 mph)
I ordered some of Doctorbass's torque arms so I am no longer afraid of adding in more torque to the bike, so a higher amp controller would be fine with me now
What kind of 24v battery should I add? Can I mix a lipo battery in series with the lithium one I already have, or is that just a bad idea? I am still reading up all about lipo's and other battery options so for now I haven't made a decision on what to do in terms of batteries.
One last question. If I do get a top speed of around 55-60 km/h with the 1500W and 72V, what kind of range can I expect with how many ah? Say I were to add a 24V 10ah battery to my current system. What range could I expect? I figure that if I won't be going as fast as I wished, I might as well increase the range
Thanks so very very much guys for all of your help! This has been such a great learning experience for me and I'm glad there are so many helpful people on this forum
