Dauntless
100 TW
ElectricBikeNoob said:teslanv said:LOL.
The last thing you will find on ES is a consensus. :wink:
Lol ....cut a noob some slack...
Oh no, you'll definitely get no consensus for THAT.
I simply don't agree!Dauntless said:ElectricBikeNoob said:teslanv said:LOL.
ElectricBikeNoob said:My weight: 180~ lbs. (81 kg)
My bike : Trek Verve 3 (Hybrid)
Motor kit for 700cc (28-29inch tires) with throttle and PAS
Desired top motor speed: around 20 mph (32kph) on level ground
Desired top speed while pedaling: between 20-30 mph (32-48kph)
Desired range: About 20 miles (32 km) with mild pedaling at around 15 mph (24 kph)
Will probably commute on average about 8 miles (16 km) a day
Terrain: 92% street 8% off road
Flat to mild hills, mild dirt paths and grass
-NO extreme mountain biking-
Brakes: Doesn't matter, as long as it works great and bike stops in the end lol.
Budget: $800 MAX
Budget: $800 MAX
teslanv said:Best value for a decent Hub is a Yescomusa kit. Get a 1000W Rear Kit.
http://www.ebay.com/itm/48V1000W-26-Rear-Wheel-Electric-Bicycle-LCD-Display-Motor-Kit-E-Bike-Conversion-/371289491857?pt=LH_DefaultDomain_0&hash=item5672940991
Yescom's ebay user name is "xcceries"
Spend the rest on the battery.
You will need Multistar LiPo to get a battery to meet your specs in that price range.
Such as two of these multistars in series.
http://www.hobbyking.com/hobbyking/store/__72326__Multistar_16000mAh_6s_10c_US_Warehouse_.html
And let the "Don't recommend LiPo to noobs" responses commence...![]()
But seriously. It can be done. You just need to educate yourself on WHY LiPo is cheap and more dangerous than various other Lithium chemistries.
BTW, the set-up I just listed will get you ~24MPH top speed and over 20-mile range on electric only.
wesnewell said:Most people can't build a reliable battery pack from 18650 cells. 29E cells are continuous rated at <3C and perform best at <1C where they still don't produce their rated capacity. They will sag bad under load even in a 6p 17.4ah rated configuration compared to a 10C continuous 20C burst rated 16ah rated rc lipo pack. I wouldn't use 29E cells if they were a buck each when I can use 20C/30C rc lipo that I can plug together in seconds for a pack for 33 cents per wh.
http://lygte-info.dk/review/batteries2012/Samsung%20INR18650-29E%202900mAh%20%28Blue%29%20UK.html
Time to learn.ElectricBikeNoob said:Dude.. I am a NOOB....I understand none of this jibberish
wesnewell said:http://endless-sphere.com/forums/viewtopic.php?f=3&t=70169
I can't recommend anything without knowing what country you're in. Please follow the instructions for doing that.
http://endless-sphere.com/forums/viewtopic.php?f=3&t=66302
To match the capacity of the Multistars, you would need 12S6P of the Samsung 29E cells. I would not task a noob with assembling an 18650 pack. So OP would need to buy one.riba2233 said:wesnewell said:Most people can't build a reliable battery pack from 18650 cells. 29E cells are continuous rated at <3C and perform best at <1C where they still don't produce their rated capacity. They will sag bad under load even in a 6p 17.4ah rated configuration compared to a 10C continuous 20C burst rated 16ah rated rc lipo pack. I wouldn't use 29E cells if they were a buck each when I can use 20C/30C rc lipo that I can plug together in seconds for a pack for 33 cents per wh.
Please, lol. You know that icecube tested multistars and found out that they are 2.5-4C realistically?
Also, I'm actually using 29E pack, and it performs flawlessly. This guy is building a bike, why would he need 10 or 20C cells with relatively bad energy density? You want to have as small and as light as possible pack on your bike. 29E and multistars have aproximatelly same power density, but energy density in on 29E's side, and also a price if you are building pack by yourself. And that's only initial cost, 29E will last much longer, and be even cheaper.
Again, not to mention quality and reliability of these two, it's really impossible to compare.
So, lets sum it up, Samsung 29E have:
-same power density
-better energy density
-lower price
-better quality and reliability
-longer cycle and especially calendar life
-better consistency, less likely to get out of balance
It's true that they are harder to assemble, but you can actually buy a high quality assembled ready to use and charge pack, which cannot be said for hobbyking lipo.
spinningmagnets said:I read the first post and you have a Trek Verve 3? Aluminum frame, hybrid = front suspension with skinny tires (to reduce road rolling resistance)
stand by for a couple minutes while I write the answer...
teslanv said:To match the capacity of the Multistars, you would need 12S6P of the Samsung 29E cells. I would not task a noob with assembling an 18650 pack. So OP would need to buy one.
Riba, if you have a source for a built 18650 pack like this for under $400 shipped, please share.
riba2233 said:teslanv said:To match the capacity of the Multistars, you would need 12S6P of the Samsung 29E cells. I would not task a noob with assembling an 18650 pack. So OP would need to buy one.
Since this is not a fair question and you know it, i will do the same, there can I buy a built pack with multistars, ready to charge and including bms?
If someone wishes to sell built pack, they have to pass some controls and certificates. Difference is, you can find built packs with 29E (no matter the price), but you cant say the same for hobbyking cells because pack built using those cells would never pass tests, and those cells are not meant to be used with EV's and in large packs.
Raged said:Iipo is for high powered rigs and people who know what they're doing. Under 2kw you wouldnt bother with the hassles with lipo as there's no benefit as your controller/motor cant pull 40A+. That said, people who switched from safe technology to Lipo's felt that it was faster. Combination of lighter pack, higher consistent power output or maybe their old pack was ... old. Who knows.
You asked about the BBS02 and that would be a good kit for you, except...your budget is $650 max. The best deals on the BBS02 are around $550 (with tax and shipping), leaving $100 for the battery, and the battery should be the most expensive part of the system, in order to get a good one.
First, you will want a small geared hub for two reasons. If you wanted lots of power, you have the wrong bike and too low of a budget...power costs money. First, geared hubs don't shed heat well, but you're in luck, you can't afford a battery that puts out more than 20A continuously, so a large diameter Direct-Drive (DD) hub is added weight and cogging (magnetic drag) that you don't need. A geared hub freewheels easily when you are not using power, and due to the small size of any battery you can afford, you will be pedaling half the time.
If you get a Bafang BPM, you could get more power later by upgrading the battery when it wears out a couple years from now, while only using 20A for now. If you are certain you will want a very light system, and will not want to hot rod it later, the Q100H is popular right now. Front hub is not a good idea on this bicycle, so shop for rear hubs only.
Just to give you an idea, Green Bike Kit has the BPM (minus battery) for around $200 (Plus T&S) when it is in stock. http://www.greenbikekit.com/electric-bike-kit-1/rear.html?p=1
and BMS Battery has a Q128H kit, which is slightly larger than the Q100H (minus battery) for $138...bearing in mind both these companies have high shipping rates to make up for low catalog prices. https://bmsbattery.com/ebike-kit/400-q128-48v400w-500w-rear-driving-bike-conversion-kit-ebike-kit.html
Shoot for 48V, you really need to sacrifice to get that because you need to limit the amps, because high amps will be bad for the motor, the controller, and the battery due to high heat.
You need a strong torque-arm, do not skimp on this.
Something that fits your budget THAT I DO NOT RECOMMEND, is to get a cheap ebay DD rear hub kit (yescomusa?) and a large LiPo battery with a non-balancing bulk charger. LiPo needs to have each cell balance-charged once a week. Cheap LiPo batteries that are only bulk charged, and don't have a reliable low-voltage-cutoff, and use cheap chargers that occasionally over-charge...they sometimes catch on fire. LiPo is not for someone who is new to E-bikes.
