Did another longer ride, wow... the acceleration.. it's at half current limit and only 100v but I swear 0-60 in under 3 seconds for sure. Probably a LOT under.
I would guess top speed is around 100km/h at my current 100v battery limit, so when I push that up to 40s it will be quite something, for sure I'll hit the 120km/h I wanted. The accel is just ridiculous compared to my other bike, which I already thought was pretty amazing. Basically I will probably see you guys at the racetracks if there are ever any races within say 4-5 hours of the border.
I really like the smoothness of the Kelly, a huge improvement over the Infineon and I had no idea I was even going to notice the change. The throttle I have is way better too; changing my old thumb throttle/ brake lever combo to another 5k pot is a priority.
Getting my rear calliper mounted is a huge priority, as is getting the regen working. Stopping from 100km/h with only the front caliper is just... slow
My second run was 5kmish, did a bunch of high speed launches which really burns power, and Im now seeing something like 4ah going back into my battery. That would be 400wh or about 80wh/km to cruise around medium speed (60km/h average) and do 5-8 hard launches up to speed. Knobbie tires are not helping the efficiency, but will be great for offroad
And finally... don't assume that your old bike will look good to you once you build a new better one, even if the old one is perfect for what it needs to do...
