unclejemima
Regular
I've got 2x 18v Rigid power tools batteries wired in a series running on a 350w 36v brushed controller on a 250w 24v brushed motor. So the motor spins faster than its designed...but its fine for the little I use it and seems to work good.
Regardless, I've got a battery gauge/voltage readout hooked up to one of the controller leads that outputs voltage. I'm not certain the exact function of the output as the controller writing is in Chinese, but it's small gauge, like 18 or so...so it's not a motor lead, I assume its for accessories or something...anyhow, when I hookup a meter to it, it reads about the same as the battery voltage...perhaps a bit lower. I think it shows about 41v, where the actual battery output shows about 42v.
All works fine, but when I apply full throttle with no load (IE, the bike is on the stand)...the voltage drops just a bit. But when I'm on the bike, the voltage drops significantly. Say I'm around 41-42v charged, when I load up the bike at full throttle, it drops to like 38v on brand new, fresh, fully charged batteries.
Is that normal? Or is it perhaps because my battery gauge is not hooked up directly to the battery leads, rather an output from the controller?
Let me know!
Let me know!
