Hello guys!
Who has pre-orders for 6F controller, numbers from 290C to 1000C, we are ready to send the order.
You will get a new version of 6F 2.0. Dimensions 53x32x91 mm, 12V 3A on board, phase 120A, battery ~90A.
The cost of 170 USD, display 90 USD. Also, you can choose the accessories at https://nucular.tech/#accessories.
Important!
All new 6F are by default with compound fill (IP67, better cooling), if you do not need to fill, the cost will not change, in this case, the board will be covered with a varnish. The filling is full, you can't add any wiring after filling, so think about your connecting scheme in advance.
By default, the output from the controller:
- the phase wires, 11AWG motor bullet 5mm jack (female connectors in the kit)
- the battery wires 12AWG XT60 jack (mating connectors in the kit)
- the halls wires
- CAN wire to display, 1.1 meter length.
And remaining two connectors in the controller PWM/PAS (5V,12V) and Control (alternative gas/brake connection to the controller, by default connection to the display). The schematic here is https://drive.google.com/file/d/1KkEgWcJ5U-AEkk6GrXhDNlYXFCcsjpUQ/view
For delivery at the moment we use the Russian company DPD, which delivers through UPS. We have tested for Europe, Australia and USA, everything is fast and reliable, parcels are delivered in a short time. The cost of delivery is not expensive.
Write to me in pm, to sales@nucular.tech, or Telegram @DmitryBogdanchikov
