I have no experience with stock controller. I ran mine with PV 12fet (with some issues). Got about a year with alfine 8 speed igh at 70A bat. After upgrade to nuc12fet, igh gave up after a month. Next igh lasted another month. Used 80A bat. And I was careful when shifting.gman1971 said:How well does it work? Is it noticeably better over the stock BT controller?
minimum said:I have no experience with stock controller. I ran mine with PV 12fet (with some issues). Got about a year with alfine 8 speed igh at 70A bat. After upgrade to nuc12fet, igh gave up after a month. Next igh lasted another month. Used 80A bat. And I was careful when shifting.gman1971 said:How well does it work? Is it noticeably better over the stock BT controller?
Now have mxus3k because I need reliable commuter
Setup was easy, took away motor chain for autotune.
briangv99 said:Hi VasiliSk,
is the next batch of 12F available soon? Lossing hope that I be able to get one of these after 6 months on the waiting list (pre-ordered 28/9/19).
Brian
gman1971 said:briangv99 said:Hi VasiliSk,
Brian
I was giving this some thought.... really, 6 months?? Wow, I am sorry to hear... well then, looks like I will probably look elsewhere. Thanks.
G.
cheeko said:gman1971 said:briangv99 said:Hi VasiliSk,
Brian
G.
Its worth the wait iv had my 12F since last year best controller i have rocked, Unreal nothing compares from others i have tried, Can't wait for BMS to be finished
This.john61ct said:Just get a cheapo to tide you over while waiting for The Real Deal
PITMIX said:pre-order is free.
Unless he starts outsourcing the assembly process, if you delay getting into the queue, likely you'll need to wait well into 2021.gman1971 said:Maybe when the October preorders are fulfilled I'll think about it.
Brian
Connect randomly and run autodetection....gman1971 said:Hi VasiliSk,
So, do you know what the setup for the motor hall sensors on a Cyclone is? Does anyone who has done this for a C3000W motor have some wiring diagrams as to how to connect the C3000W motor to the Nucular?
Thanks.
G.
