nylon and aluminum pulley any good?
Sausalito
getting a pulley to match my 5mm htd 9mm width wheel pulley
sdp is out of 16 groove.
how bout this one with nylon:
http://catalog.torquetrans.com/catalog3/d/torquetransmission/?c=products&cid=pulleys-htd-5mm&id=31607-F
I've never used anything but aluminum motor pulleys, but I have used cast resin plastic wheel pulleys with great success. They have all held up nicely.
I only use steel motor pulleys. Alum will eventually wear down.
Alum for the wheel pulley.
When you think about it each tooth on the motor pulley gets 2.5-3 times more friction with the belt vs the teeth on the wheel pulley. So if they are both alum the motor pulley would wear out much faster.
Hummina Shadeeba said:
Don't see any steel 8mm bore wheels that are 5mm htd, 9mm wide
I'm looking for a 15 tooth
Yeah, I don't think there are any...
