DanGT86, a modern multiplate clutch in a supersport will easily take ~200+hp for tens of thousands of miles, including aggressive launches and the like - wet bath multiplate clutches on modern motorcycles are pretty absurd in terms of the abuse they'll take. MotoGP bikes only have a single launch, but are easily taking over 300hp out of a dry clutch assembly. So there's no need to build a custom clutch assembly. The clutch on the EM is tiny relative to what a gas dirtbike runs, and the overall output of the QS138 motor is about 50% of the output of a 300 2t motor, even if you burst to ~25kw.
My long term plan, if the concept plays out nicely, is going to be to build a gearbox based around a KTM 6 speed assembly. The first prototype will just have the electric motor drive the crank, to be as close to the 2t design as possible and to see how that plays out. The second version, I'll get a set of cases and remove the crank assembly and figure out how to drive the clutch basket directly, with a flywheel weight on the output shaft of the motor (or potentially on the clutch basket itself).
Third version, once the setup is proven, I'll explore custom designed assemblies. Until then, too much money for an unknown outcome - it's very easy to find a KTM woods bike and weld a sprocket to the end of the crank. If you wanted a very simple thing to prototype with, you could buy a motorcycle clutch, primary drive gear, attach a flywheel weight to the end of the motor, and attach the clutch basket to a jackshaft, and have a very straightforward drive system with a clutch. You'd probably want to put it in an enclosure, as they like to be bathed in oil.
Here's a good video of a 2 stroke bottom end disassembly, if you're curious about the design on modern motorcycles:
https://www.youtube.com/watch?v=gp8CHmG6nw8
bikerpete said:
That's very much the minimum skill level clutch intro. Even in the clutch pop he still talks about using throttle to lift with - that's well and good if you're aim is just to get the front up and roll along, but it's pretty limited.
If enduro is your thing I quite like this Jarvis video with his clutch finger in the corner of the shot. It really shows just how much it's used and just how quick you can go from power-on to power-off and back again, and all the nuance in between - trying to do that on throttle alone would give you RSI pretty quick as you snapped your wrist back and forth like a lunatic, besides being nigh on impossible as you move around over the bike. Notice how the clutch hand is rock steady.
https://yewtu.be/watch?v=En4pLTEUY70
Yeah, Jarvis is great - I figured I'd give the simpler intro for folks who didn't have experience with the style of riding, though
bikerpete said:
No, there's not!
A bigger motor does nothing for accurate, fine control - I'm surprised to hear you say it.
Why oh why do people have this fixation on bigger is better?
I think if you're comfortable scope constraining the usecase, it's a 6 of one / half a dozen of another argument. If you assume no one needs to go over 90mph, moderate (for a motorcycle) acceleration is fine, you can avoid a large number of complex systems, by running it as a single speed. If you accept certain scope constraints, the lack of a transmission makes a lot of sense. Simpler, less drag, less stuff to maintain, cheaper to assemble.
The Brammo, IMO, has way too many gears, and it felt pointless to have to shift so much. You could easily ride it around in 4th all the time, and it was fine, although it was a lot more fun around town in first or second, just belligerently fast off the line - if I was on my KTM SuperDuke 1290, I had to basically do race starts to keep with it up until about 30mph (at which point, he'd be shifting to second, and I'd finally have the clutch out and blow by him). For your average rider, I think a single speed is fine, and the simplicity and low cost of maintenance is appealing (no oil changes!). When you start to get in to the more specialized use cases, I think everything changes, and the flexibility of the gearbox allows the bike to excel in significantly more situations than you would with a single speed alone. I definitely got lazy and just rode the Brammo around in 4th gear sometimes, it wasn't inspiring but it also wasn't designed for that.
If your curious, here's my hot lap at Refuel, back in 2013:
https://www.youtube.com/watch?v=_H6FRplenUg
You'll note I never use any gear below 3rd, and the bike can't really pull much over 100mph even with a fairing on it so first and second are just along for the ride. The zeros, with the single speed setups, were quite fast, although they had overheating issues given the amount of time you spend at full throttle around a track. They also saved time by not having to shift. If I had the choice of a 3 speed (3rd, something between 4th and 5th, and 6th) and 10-20% more power, I'd absolutely have taken that, for this specific use case.
Been a long day, so apologies for my rambling as well
Nice to participate in this conversation! Can't wait for my parts to show up!
