Got an ebike battery that's not behaving. It's a 48V 10AH battery.
Setup is:
My sons bike - new setup only a few rides on it.
Fat tire bike with rear 1000w direct drive hub motor (chinese brand CSC)
twist throttle
LCV readout (sw900)
So the battery at full charge reads around 54V. but only getting about 7-8km on a full charge. He headed out but battery died on his return. Completely... would not turn on. Put it on the charger for a few seconds and battery works again.
I ran the bike around the block until the lcd said the max Watts were around 200-300 and very low power. during this the battery gauge on the lcd was showing no bars, but letting off the throttle the battery gauge would come back up to around 3/4 full.
once I got back to the house I disconnected the battery and checked the voltage at the main power leads and it was still reading about 48V.
This is where I got confused as per my understanding at 48V it should still have lots of power unless there is something wrong... which I'm guessing there is... just not sure what.
spent quite a lot on the battery but was purchased second hand (unused though) as he had received an incorrect battery and sold it rather than return it. So getting a refund is pretty much off the table.
Another thing... during the build something contacted inside the charging port (barrel type) and shorted it... very energetically. port was destroyed and I had to replace it.
Wondering if the BMS might have been damaged... or if I have a bad set of cells in the battery. Any help would be appreciated.
Setup is:
twist throttle
LCV readout (sw900)
