I got some PCBs from Jacob a week ago and yesterday I spent all day soldering, debugging and testing:
I had to make a patch for the regulator to work:
A CP2102 PCB makes a built in programmer:
USB Port for programming and charging:
Here ts is next to the nyko kama:
I went for a 6km ride yesterday and it worked perfectly. I have tested the nyko kama with my early version of the PCB for months now and it has been super reliable, so this one should also work well.
The features of this nunchuk are:
* The connection is solid and reliable.
* Built in rechargeable lipo battery and built in charger
* USB port for charging/uploading firmware/configuration/debugging
* Standby time: over 100 days on a full charge
* Usage time: almost 2 days on a full charge (about a month if the longboard is used 1 - 2 hours every day)
* Lighter and smaller than the nyko kama
* Charge time: 1 - 2 hours
Much of the time I spent yesterday was on testing the power consumption in low power mode and how the charger works, which was much better than I expected. First I thought a power switch would be needed, but that does not seem to be the case unless you intend to leave it without charging the battery for more than 100 days.
I will help Jacob with updating the design a bit with the following:
* Connect the regulator correctly
* Remove some resistors that aren't needed
* Change the joystick footprint and position to make it fit better
* Add a CP2102 USB-to-UART chip to the PCB so that the programmer is build in. This will allow a twice as large lipo battery which doubles the standby time and usage time.
* Add something to make the MCU able to measure the battery voltage.
