Hyena
Hey guys,
With my previous favourite bike (norco dirt jumper) now gone (sold) it's time to start on my next build, and up the ante a bit
Here's what I have so far, after 2 big boxes of expensive stuff being delivered in the last few days I actually have pretty much everything to build the bike!
The frame is a Sintesi Bazooka which apparently has a pretty good name in the DH world. I was just on the lookout for a good full suspension frame and fellow Aussie ES member full throttle hooked me up with this one. Thanks mate!
The motor I'm going to use is a 9C 8x8 which falls somewhere between the 6x10 and common 9x7 windings. It has the most copper fill off all the 9C motors and an initial test on 15S lipo has shown it to be pretty good. Plenty of torque and it pops the front wheel off the line very easily with a jab of throttle. My old bike was running 18S lipo and had heaps of grunt, this one will be 20S (84v hot) and using a 100 amp controller so I reckon with over 10hp she'll go alright :wink:
The set up will be pretty much for off road use (I'm rebuilding my commuter bike to have both better suited to their dedicated purposes). The above pictured forks will go back on my commuter bike and my marzocchi bombers and 9" hayes stroker ace hydros will go on the bazooka. The back brakes will be 8" mechanical discs for now. I'd rather hydros all round but I'm not too fussed about the back brakes, they don't need to be strong anyway as the fronts do most of the work
The bike will be running a 24" sun double track rims front and rear - the front is already laced to a 20mm nukeproof hub. I have to get some custom spokes to lace the 9C. I wanted wider tyres but for now I'm running dmr moto diggers (24x2.35) Later I'll upgrade to halo Ception's which are 2.6" wide 8) Handlebars are moto style as picture above.
I can fit 15S2P lipo inside the frame but the remaining 5S2P doesn't quite fit. I'm not sure how I'll set it up yet, whether I make a wider section at the front and run the packs 2 wide or put 2 on the top of the top bar (as shown).
The first step will be to rub back and paint the frame. It's well used so has alot of chips and scratches.
I'm thinking satin black to match in with the black rims, forks, bars etc but am also toying with the idea of a dark camo colour scheme for the frame.
Stay tuned
Stay tuned
