Ira said:
there is a torque arm on one side. the axle is oversized and has flats on it, which fill the dropout entirely. it fits so snugly that i had to file off the paint. it seems unlikely there would be rotation unless the dropout is deformed.
edit - i don't meant to sound like a know-it-all here, as this is my first attempt. should i be worried about torque damage to the dropouts, despite the single sided torque arm?
Depends on the torque you put thru it, and if you use regen braking. It's possible that nothing will ever fail, but I prefer to be pessimistic where it concerns having my vehicle fail while on the road somewhere. (has happened too much).
Using the latter means the axle will be rocked back and forth, as no fit is ever quite perfect, and each cycle will slightly enlarge the gaps, increasing the rocking, until:
http://www.endless-sphere.com/forums/viewtopic.php?p=545492#p545492
Even with torque arms, it's still possible to spin the axle in the dropouts.
Personally, I prefer at least two torque arms, if going higher than 500-700W depending on the torque load. Some will say 1000W, or higher. Depends on axle and dropout and torque arm material, torque arm thickness, axle flat size, torque you put into it, etc.
I also spun a geared hubmotor in a steel front dropout, at around 1200W peak, IIRC, during a startup from a stop. Tore up the wiring some.
I suspect the axle nuts were not fully tightened, though.
The torque load can be higher for longer durations if you have a heavy bike, or cargo loads, or heavy rider (or all three). Crazybike plus me is around 300lbs, much more with cargo on it, and up to double that with heavy cargo plus a trailer full too.
