Chalo said:
MadRhino said:If you mean big nipples for smaller spokes, check Sapim reduction nipples.
999zip999 said:I think I have about 30 of them used the ones you need I think I bought 40 of them but I don't know where the other 10 could be they've been sitting around bounce around for like six eight years in my drawer. nipple head.
I can mail them to you as I'll never use them. Used.
999zip999 said:That bill would machine do cut threads is easy to wear out. Plus a cash thread it doesn't roll thread I like it but it wore out quick. What size bolts are you putting in
DogDipstick said:YOJIMBOS GARAGE on FACEBOOK
He is great got what you need ... Plus a Phil Wood machine to boot. Got the nipples for my Sur Ron DOT rims from him plus cut spokes. Or try Treatland.tv of course.
DogDipstick said:"The thread is rolled/cold forged onto the spoke, which does not remove material as would occur if the thread were cut into the spoke." "Our machine is capable of cutting carbon steel, stainless steel, titanium, anodized, and powder coated spokes ( to length)." " If properly maintained, each surface can roll 60,000 spokes, for a total of 120,000 spokes on a single die set. When cutting and threading standard spokes, some die sets have reached upwards of 160,000 spokes. "
https://phil-wood-co.myshopify.com/collections/spoke-machine
markz said:I wonder how many Hozan can roll?
I would have saved money on all the custom spokes I bought.
Plus I could even put an ad in the online classifieds promoting my custom spoke service.
https://www.amazon.com/HOZAN-Spoke-Threading-Machine-C700/dp/B000C3F5LY
I believe they are $150usd with one included attachment and each attachment is like $50.
DogDipstick said:I hear the Hozan is kinda painstaking... hence the popularity of the other tool, and the price.
Chalo said:One of those can roll more spokes than any normal human has the patience to do. My coworkers think I'm a freak because I'm willing to precisely cut to length and roll threads on an entire wheel worth of spokes at a time. Expect an hour per wheel when you've gotten the hang of it and you have a rhythm.
DogDipstick said:Yeah I have almost bought a HOZAN like three or four times by now, researched th Cyclo and everything, searched and searched. I really want to be able to do this.. Cut and roll my own spokes, but could never commit to a Phil Wood kinda machine. Lol thats outta my league.
thanks for the input.
.You will need to dish these washers into a shallow bowl shape, which is easily done with a cheap 3/8-inch hydraulic tubing flare tool. Standard 12ga bicycle nipples will require washers when used on any moped rims. Common 12ga nipples have a 4.6mm body, and a 5mm washer works well. An SAE #12 washer has a 6.4mm ID
ZeroEm said:Just wondering if anyone has tried using aluminum or copper tubing flared on one end. Have the nipple fit into, thru like a sleeve.
spinningmagnets said:which is easily done with a cheap 3/8-inch hydraulic tubing flare tool. Standard 12ga bicycle nipples will require washers when used on any moped rims. Common 12ga nipples have a 4.6mm body, and a 5mm washer works well. An SAE #12 washer has a 6.4mm ID.
Try one washer, if it works for your rim, you can buy more...
