motor will heat up also faster so watch out. i burned one and then i modded one with holes in the case, worked a little better. at some point of higher voltage the mosfet will fry. this will be bad because in a brushed controller the failure mode is full throttle. my razor scooter at 60v....failed at half throttle and went to full throttle during a test ride. the scooter took off on its own leaving me running and flew across the parking lot like a slingshot hahahah
i would try 36v ....no more
mind you 36v could be 3x14.4v(float charge voltage of fully charged lead acid 6s cell so 42 volts......mabye try a 10s lipo??
