I picked up a URLIFE E20 e-bike from AliExpress recently. Overall, I really like it, but I’ve noticed two things that bug me a bit:
PAS only has 3 levels (1–3), and even level 1 feels way too strong. I’d love to have 5 levels with a much weaker level 1.
The PAS sensitivity is super high. Just a tiny pedal movement kicks in the assist, which gets annoying and dangerous.
I know a lot of e-bikes have hidden “P-code” or “P-settings” menus to tweak stuff. Normally you get in by holding + and –, but that doesn’t work on the E20.
After playing around, I figured out the trick:
Enter Menu: Quick double-press Mode right after powering on
Scroll Codes: Use + / –
Edit Value: Single press Mode (value flashes)
Change Value: Use + / –
Exit Menu: Quick double-press Mode again
The menu seems kinda limited, though. Here’s what I found so far:
P1: LCD brightness (0–5)
P2: Sleep timer (off or 1–10)
P3: Units (0 = metric, 1 = imperial)
P4: Starting PAS level (0 or 1)
AO5 / A05: ??? (see below)
FAc: ???
The weird thing about AO5 is:
If I press Mode, it changes to P50 (or PS0??) with four dashes at the bottom, and I can set each dash (0–9) with +/- buttons.
Once all four digits are in, pressing Mode again just shows “Ehh” and kicks me out.
Looks like it’s waiting for some kind of passcode to unlock advanced settings.
Has anyone here cracked this yet, or figured out if deeper settings exist on the E20? Would love to tone down the PAS.
FAc: ???
