Little Voice
- Joined
- Aug 4, 2019
- Messages
- 29
Hi Folks my first post on this forum which I am new to, so sorry if this has been covered before (I have done some searching but not found an answer) and thanks for having me. Hopefully I am posting in the best section for this topic.
I am not an electrican, as will be evident from viewing my first sketch of a, for now, theoretical, Solar trailer powered, PAS E-bike with Bafang mid motor.
Hopefully it makes sense, it lacks some details but I thought best to keep it simple.
A small intro to my project:
As solar power tends to vary in temperate climates (bright and also cloudy days), then although down-stepping MPPT charge controllers are more efficient, boost ones are more likely to be working all day long (although only a little when completely overcast). The boost MPPTs obviously need the voltage to be lower than the target battery voltage. Whilst trying to maximize the solar power input, I therefore I have decided to try and run 2 smaller batteries in terms of Amp hours and run them separately until they meet at the motor (controller) connection obviously. I am not a programmer and want to keep the system as simple as possible (therefore not wanting to write a small circuit board program to manage things, plus it means less to go break and fix). So I am willing to monitor the batteries myself and switch manually between them. Bosch says of their dual battery system, that by alternating between batteries (say using 10 or 20% of one then switching to the other) it allows the battery to recover when not in use. In theory using this design will be getting a rest and a top up charge too, if it works.
Having not built an ebike before I have been studying up somewhat, in an effort to look before I leap.
I have read a posts on ebike forums etc that say with parallel batteries if one is in a lower state of charge the other may discharge into it.
This was a potential problem I was stuck on for a few days until I discovered the Luna Remote on-off Solid State Switch, so now I have hope again. Weblink to that here https://lunacycle.com/remote-on-off-solid-state-switch/
It is possible that I could make a mistake and put both batteries on at the same time, and I am hoping that wouldn't be an instant disaster if I do (and have the Luna Remote Solid State Switches installed).
I am not too sure if the remote on-off solid state switch's MOSFETs will block discharge from the other battery or not please?
Does it have an in-built diode or some other effect to stop or limit cross current between batteries please?
Also does the remote micro switch get powered by the main battery or do I need to add a small charge to it from elsewhere (and if so at what volt/amps) please?
Maybe this wiring is all wrong? As I said before I am new to e-bikes and keen to learn, although I have done a fair amount of cycling at least albeit it years ago.
I am very happy that ebikes have grown over recent years, and I have gone without a car for many years now and see E-bikes as a low impact solution that can help people manage our impact on our beautiful world and get some exercise too.
Please ask if I have left any important info out that's needed to respond to my questions, thanks.
Thank you very much for any help, advise, suggestions and tips that you may offer.
