hi i am new here and i am just getting into building ebikes. i have two battery packs that are for scooters and one of them has a busted bms. they are identical battery packs, both are 10s3p 36v 7.8ah. i was thinking of just wiring them together to share the same bms so they can charge and discharge together. i have been doing my homework on this website and i came across this post by dnmum
"you can use just one of the BMSs that is installed on one of the packs. tie the B- and B+ terminals of the two packs together, connect the two packs through the sense wires so each cell is parallel with the same cell in the other pack, and then use the P- connection for the motor and the P+ is the red wire from the top of the two packs tied in parallel. then they both operate together as one pack, charging and discharging."
it seems like this should be easy for me to accomplish but i really don't want to mess anything up and ruin my battery packs.
i am looking for some extra clarification and maybe a bit of hand holding..
i have attached a photo of the bottom of my busted pack. the battery packs are the xiaomi m365 battery packs.
along the bottom of the pack it has metal pads labeled b0 b1 b2... b10. are those the sense wires that i would need to connect to the other battery?
what else do i need to do exactly? what are the p- p+ b- b+ exactly? im having trouble picturing this all in my head..
thanks!
https://imgur.com/a/uOnmGUc
thanks!
