safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
You take a bunch of parallel connections from your battery and feed that voltage (let's just say it's 12 Volts) to a row of 10 ultra capacitors at a rate that is "conservative" for your batteries drain rate. So you make sure that if your battery chemistry can only handle 1C that you drain them into the capacitors at no more than this rate.
Okay, so now you have a bunch of "charged" capacitors.
Now what you do is press the "Turbo" button and all these capacitors get linked together not in parallel, but in series. How do you do this? I don't know, maybe with relays, but the idea is that you charge at one voltage and then discharge at the combined voltage.
All of a sudden your normally "tame" motor that is normally getting 12 Volts as input all of a sudden has 120 Volts that will for a short period of time produce a "rocket". Once the capacitors are spent then you go back to your normal voltage and in the "background" the capacitors are being recharged for the next time you use the "turbo".
You could even use the "regen" to fill the capacitors along with the battery. But in a lot of ways having a freewheel is better because you could get this huge burst of accelleration and then just coast for a long way. In this way you could have for very short periods of time an "extra taller gear" that would not ALWAYS need to be set up this way. The normal riding would be at the low voltage and only the "turbo" would be at the added voltage. A factor of ten might be too much, but you get the idea of how far you could take this if you wanted to.
So what's going to blow up first with this?
You might want to "go around" the controller on this one. Somehow bypass the controller and just get a straight shot from the capacitors directly into the motor until the energy runs out...
