Hello,
I ran into a problem when moving my rear hub motor kit to another bike frame that has a Race Face Atlas crank and bottom bracket installed. My PAS sensor disc is made to mount on smaller spindles, but won't fit on the over-sized spindle that Race Face uses.
I was about to give up and switch out my cranks and bottom bracket, but thought I'd ask here to see if anyone has encountered this and has a solution. I read another post of a member gluing the sensor ring to his crank on the chain ring side, so one thought might be to add a washer between the right crank arm and the bottom bracket/sealed bearing to create enough space to do something similar.
Anyway, any ideas are welcome.
Thanks!
Thanks!
