cfunni
New here
A little background. My wife has a Electra Townie Go, and the Battery died, and due to the communication requirement from the controller to the BMS system in the battery, just changing to a generic battery would not work. So I purchased a basic kit with a LCD display, controller, throttle, PAS, and a generic 36V battery. Install went fine and bike works good except the PAS is too fast. Throttle is as expected, but when using PAS, level 1 is no assist, level 2 or above is way too fast. The motor is a rear hub 250 Watt OEM from the original set up. I have made every change in the configuration with no change in the PAS reaction. The bike surges way to quick, and speed is too fast to the point I am afraid my wife might loose control. I have ordered a new PAS to change, but if anyone has a suggestion I am all ears.
Thanks
Craig in Houston
Thanks
Craig in Houston
