xyster
So, with my battery pack's voltage at ~3.9V per 15-cell subpack (20s15p pack), I hooked up my 20 chargers to my bike's 20 jacks for an overnight partial charge as usual.
Before heading to bed, I checked to make sure all chargers were charging (each light red). But one light amongst the 20 was green -- meaning charging had ceased to one of the subpacks! It was too soon for charging to be completed, so most likely, I thought, one of the twenty charging plugs just needed a little wiggle, like sometimes I have to do.
So I wiggled the plug in the jack, but the charger's light did not switch back to red. So I checked the voltage of this misbehavin' subpack.
4.16!
That's done as far as these chargers are concerned. But this couldn't be right because all the other subpacks, starting at the same time and about the same charge-state, were only at 4.0 volts.
On a hunch, I kept the DVM's probes in the charger jack and switched on the bike's lights. Voltage immediately plunged to 4.0V -- right where it was supposed to be! I turned off the lights, and the subpack's voltage stayed at 4.0.
I plugged the chargers back in. The 20 lights on the 20 chargers turned from green to red as they should.
This is the second such incident with this particular subpack. It's never happened to any of the other 19 subpacks yet.
The problem is not in the voltmeter either, as the charger wouldn't have acted as it did if it was.
So folks, what happened?
Do some batteries or connections sometimes carry a little "hot spot" of extra charge that must be dissipated?
Should I be concerned about a bad cell or other subpack problem?
4.16!
