Hi, first timer and new to e-bikes and have no idea with all things electrical, so please exercise some patience.
We bought a cheapy valk ladies step thru e-bike with rear hub 36v motor and pedal assist. The chain popped off in the rough stuff and I think that cracked the plastic disc behind the crank arm that houses the magnets for the pedal assist sensor. Either that or it got squashed when we loaded it onto a 3 - bike carrier hitch with another two bikes. Anyway, I couldn't find a direct plug-and-play replacement as all cheap generic online stuff has a different plug and wiring setup, but I ended up buying a cheap kit anyway because I only need the disc and not the wiring and cable connector back to the hub. I think the original disc had 5 or 6 magnets but I went with a 12 magnet replacement.
I have read a bit about the different cable connectors now and ours has the 9 pin julet connector, which I think contains wiring for the three phases of the motor plus a wire for the magnet 'hall' sensors? I couldn't find the same type of wiring connector and setup with any of the pedal assist sensor kits online. My queries are with all the generic replacement stuff I was looking at, the wiring appears to only have three wires, so how do they work if the three wires are for the phase and no other wiring which I thought are for the sensors? Also, what effect will swapping a 12 magnet disc onto our bike have when it only had 5 or 6 to begin with?
Thanks,
Thanks,
