Desertprep
While reading posts in this forum I have found a comment repeatedly nested in amongst many jewels of information. I want to write this post to address it specifically.
I have read of several people with non-hub motors saying that they haven't had any problems with their motor/controller/battery setup (can I call this a drive train? or maybe power system?) because they always pedal to get the bike started. If pedaling to get a bike started will keep a system from shorting out, doesn't that mean that the controller has probably not been chosen properly? What is the spike voltage/amperage ( the momentary surge voltage/amperage) required to get 260 pounds of dead weight (rider, bike, batteries, etc) going? and how long is this amount of power needed? Shouldn't the controller be chosen to accommodate that power requirement? as well as the amount of power needed when the rider is cruising along at 15mph and suddenly gives it full throttle? Goldenmotor sells a controller that I have looked at often which is probably a huge amount of overkill. It is 24-72v but with about 300 amps - or 500 for the big brother At 8 pounds or so, it is a heavy sucker, but from what I have read in the posts in this forum and a few others, it seems like it would be a bullet proof solution for an e-bike or e-scooter with an outrunner....as long as hall sensors are installed on the motor. The weight outdoes some of the benefit of using an ourtunner in the first place but there are (in my opinion) a lot of other benefits for not using a hub motor besides the weight. I am not trying to put in a plug for this controller - I know little of it or the company - but rather am setting this out as an example to contrast the thinking used by the "pedal first" folks and open up some discussion. Please feel free to put in a plug for your favorite controller
Edit: Gosh, golden motor even sells a foot controlled "gas pedal" for this puppy - how cool!!!
