Kinni420
The pic I have above is an old pic. I moved the controller to behind the seat post. switch is facing up, wires down. Winter is almost over here and Ill keep it where Ive got it. Dont want the hassle of moving it into the bag
Kinni420 said:any chance you can give an ACTUAL link to that crank set you bought? I still need one but so pricey where Im looking.
veloman said:That's a good price for a road crankset. Ebikes need that 52/53 or larger chainring. Just beware of clearance issues on some full suspension or other mtn bikes. (with the chainring)
Kinni420 said:How's the clearance of that 53 chainring in relation to the frame? Id hate to purchase this and find that it hits the frame when I put it on. It would be a help if you could grab a ruler and let me know the approximate radius of that chain ring (In mm please!) 8)
Kinni420 said:the ONLY reason I wouldn't remove my front derailleur is for the chain-guide effect. Tossing a chain at 40 mph could be a disaster. Cheaper than spending 50-250 bux on a regular chain-guide/tensioner and a one speed crank arm+BB. Ill never shift the front again. I plan on adjusting the front D screws to hold the chain in place on the big sprocket and removing the front shifter assembly completely except for the D itself.
JKB...Did you measure the spindle length on your BB before installing? If its 110-113mm I think it will work for me and thanks for the info. Both you and Neptronix! BTW hi again Nept! It snowed a foot today here but i still went for a sketchy ride in the slush!
No, and now I wish I had. I need to go buy the crankset tools (I borrowed to do the swap). Then I could pull everything off and measure.
I THINK I've got a 110 mm BB, but I don't know. Are there any tricks for measuring with the crankset on?
JKB
pendragon8000 said:so you going to use a large spoke key to true it up? if i was you i would flip the bike and have a go at rueing it up, you can use a cable tie or two coming off the crame as a spacer to the rim.
there should be some tutorials out there... i think 12g spokes need 4mm spoke key.
neptronix said:Nice.. 19wh/mi is really impressive.
jkbrigman said:neptronix said:Nice.. 19wh/mi is really impressive.
Not bad for a 260lb meat parachute!
I love this bike. If I can just get the motor wheel issues settled and refine the controller wiring and lighting, I'll be in business. Oh, and yes, the cupholder. I NEED a good cupholder. I want to be able to buy a huge "big gulp" style 44 oz drink, something that would give Michael Bloomberg nightmares. I want to carry it on the bike, sipping in luxury as I ride to work.
veloman said:haha, that will increase your aero drag!
I think you should do a tail box, could help considerably since you are sitting upright. Put your stuff in it and definitely not in a wind catching pannier!
Ykick said:I can't say enough good things about the need for improving motor wheel builds. If it doesn't have eyelet rims and quality spokes (I like 13/14ga butted) it will always need attention. Build with decent stuff mentioned you may not need to ever touchup again.
Unless it's dirt cheap I won't even consider buying pre-built motor wheels anymore. Learn to order spokes and lace yourself, kicks ass!
jkbrigman said:Ykick, THANK YOU for that feedback, it makes me feel better. I'm getting Sapim 13ga spokes, which I understand are pretty good. In your opinion, do you end up with a superior wheel build for less money if you build it yourself?
