Toorbough ULL-Zeveigh said:
LI-ghtcycle said:
They are also some of the least efficient around (while laced to a typical 26in/700c wheel, even a 20in isn't going to cut it at the same voltage/watt hours) , when in my own testing I used only 35% of what was required to power the same hub motor on the same bike doing the same hill climb when used as mid-drive with appropriate gearing VS wasting over 60% of my AH's in heat, I think you are missing the point.
that's where you made you're mistake.
you don't use the same config hubmotor that's intended for gp use that you would for strictly climbing a hill.
do you drive a golf ball with your putter as well??
bottom line, short of a motor chilled & wound with superconducting wire, it's a hubmotor propelled EV that holds the record afaik for efficiency.
and it's not even the CSIRO solarcar hubmotor, which already stands at 96%.
LI-ghtcycle said:
Imagine two racers in TDF with equal strength and skill, one with a fixie, one with a standard geared bike. It really doesn't matter if the gear ratio on the fixie is a pretty good compromise between hill climbing & high speed flat-road gearing, the rider with more gears to use is always going to have a huge advantage.
good illustration, wrong conclusion.
*not* if the race is strictly uphill with no or at least very little variation in slope which is the case here.
the multiple geared bike isn't gonna shift anyways.
those extra unused gears are nothing but dead weight.
you bet the lighter weight fixie's gonna win that race to the top.
an excellent example of what i'm talking about.
I'm not familiar with the CSIRO solarcar, I will look that up thank you!
Correct me if I'm wrong, but aren't Astro motors also in that 96% efficient range? I mean it's just a motor after all, whether it's put into a hub or ran as a smaller diameter out-runner like the Astro's, it's as much about how the motor it's self is constructed, whether it's put into a hub or used as mid-drive right? (lets not forget that the 60%+ efficiency increase I saw in my own real world testing was using a Amped 9 x 7 (9C) DD hub motor as mid-drive. :wink: )
Don't get me wrong, I'm not saying that a hub motor can't be efficient, but as you have stated, if one is going with a pretty consistent load, sure, a hub motor (that is laced into a wheel) is going to hit it's efficiency zone especially designed for perhaps a WOT speed that will be constant for 90% or more of the race, however, in most real world applications, a hub motor, much like a fixie a hubmotor is NOT going to be efficient.
Sure if you live in the flatlands with virtually no hills, especially in a city, this makes plenty of sense, just as with the fixie/hub motor you typically have lots of starts and stops, and the lower component count, robust simplicity make perfect sense, no time wasted shifting derailleurs, just pedal!
Now come to my back-yard, Oregon City. I live on top of a hill that requires me to travel down then up for most anything that I can't find on the shelf at Fred Meyers (bicycle parts for one!) and it's going to take a huge bite out of my efficiency if I ride my hub motor bike VS that same motor used as a mid-drive.
I have to travel 2 miles of up hill that starts at a minimum of 5% (this is if I am able to "cheat" and use the elevator to avoid the first 12 -7% grade depending on which route I take) and has about 3 - 4 blocks of 7%+ grade, the worst being about 10% for at least half a block, and why lug around 20lbs of battery when for most trips going a total of 20-40 miles I can use half or 10bls of battery to do the exact same job using a mid-drive?
I'm not attacking your beloved hub motor! :lol:
I'm not recommending we start a "hub burning" (ok Dogman's exempt, he can burn what ever he likes, thanks for all your valuable testing DM by the way!
) and rid the earth of this "evil scourge" .
If I am going to the ends of the earth and want something that just works, a fixie/hub motor might just be the ticket in Antarctica, or if I just want a simple no frills E-Bike that is damn hard to kill, has few parts to fail, and just works every time I want to use it for commuting or what ever, LiFeP04 and hub motor all the way!
However, as long as it is still practical enough for me to use as daily transportation, I'm going to stick to my mid-drive and my LiPo, because for all it's extra complexity and extra parts count, it's huge increase (I consider 60% to be huge
) in efficiency, I will use it instead.
I still have and love my Amped 9 x 7 DD hubbie, and I have NO plans to send it to the scrap yard, once I have time and ability (still really sick, but getting better) I will either have it laced or lace it into a new rim myself as project as it will be my "Fixie" the bike I can just get on and ride, no fuss, no worries, no checking every little thing before I ride E- bike.
When you add the contest of man, machine and a 24 mile course like the Assult on Pikes Peak, why the hell WOULDN'T I use the best option around?
If I were to attend, and I had the funds, I would love to see how much something like a Ecospeed or my own home brew mid-drive would perform. I know the Ecospeed would handle it no problem, my own current project *might* be tweaked to be more of a performance VS the cargo bike low torque hill climber with out regard for speed that I am working on, but I would probably need a different motor than I am going to use.
Hell, I bet if it was closer, Ecospeed would have attended, but hey, they are doing just fine selling their product, and I doubt they feel the need. Would be nice to see how they faced off with Opti, I imagine they would be a very close second if not a down-right contender for the fastest time.
