No conditioning that I've heard of, unless maybe balancing and conditioning are interchangeable terms to the marketing dpt. I have head of battery conditioners for lead batteries that help bust up suphation, but that sulphation doesn't happen with lifepo4. The charger is really just an inexpensive sla charger with the voltage adjusted to match the bms. One nice thing is a second charger can be had really cheap, since regular sla chargers can be used, such as I do. I leave a cheap sla charger at work, and every other charge is done with that one. I was beating up chargers carrying them around. So if something happens to your charger, you can use a cheap substitute for awhile. For me last summer, I got away with it for 100 cycles. A good ping pack like the one I have, has pretty well matched cells in it and is pretty hard to do anything bad to, as long as your motor is not too big.
Bad cells can be replaced in a ping battery. But it is a real pain in the rear. All the lifepo4 duct tape packs are built too hard to replace cells in. That is one place where PSI and Headway have it much better. Thank god I haven't had to learn that skill yet. Ping is very helpfull with supplying any needed new cells , chargers, or bms if the unthinkable does occur. I don't know what the failure rate for his batteries is, but it is very low. The vast majority of us ride on happily and never post on the forum. Other sellers, like the Mr Lau of many selling names, have much higher rates for sending out batteries that never work from day 1.
