BlackburnPete said:
John, I am glad to hear that cycling the pack through a few charge/discharge cycles solved your problems too. I find the discussions and advice on this forum help me a lot. Even though this is not my first battery or even my first LiFePO4 pack, I still found the information in this topic relevant, especially when it comes from people who have experience with Mr. Ping's batteries and BMS/Charger characteristics. I hope it helps calm the nerves of other Ping newbies.
John, How does your scooter work with your LiFePO4 pack? How many amps does your scooter draw? My daughter has a scooter with a 48V SLA battery pack and I was wondering if one of my 48V 20Ah packs would be suitable for the scooter.
Pete;
It would be great if My. Ping included Bob Marley's "Don't worry, be happy" or wait a few cycles before you worry about the leetle lites.
On my 3rd or 4th charge, I found 2 flashing red lights
when I went out in the morning. I had already learned to not suspect the worst, so I unplugged the charger from the scoot, then from the supply. When I plugged it back in, I still had 2 flashing red lights.
Unplugged again, turned on the key and ran the motor, while on the center stand, for a few minutes. I plugged in the charger and
, perfect. I went 30Km, got out the DVM and all was well. Maybe the 2hp vacuum cleaner, on the same circuit, shot a spike, maybe the 250 amp welder on the mains, who knows?
I'm not dragging out the Tektronix Dual Channel until the smoke gets out and I really have to figure things out. Save the brain for enjoying the pleasures of life.
I have never calculated or measured the draw. My TS battery is 60V @ 40Ah. As you are in the land of Celsius; I comfortable go 60Km at 60Kmph, with many hills on the trip. I often go 80Kph+ for the last 5Km+. WOT gives me 55-60Kph on the last 2 hills to home, after the 60Km trip.
Either my speedo error is growing or Mountain Chen's advice that the pack will get stronger after you exercise it a few times was correct. Top speed has increased 3kmph after a few charge cycles.
The first two scoots I tried were 500W 48V 12 Ah and 500W+ 20Ah SLA. Great fun on the flat, but totally useless on a modest hill. One of the fellows installed a 20Ah LIPO in place of the 20Ah SLA and it is a totally different machine. The range is almost double and the discharge curve is so relatively flat, there is no comparison. It appears a 20Ah LiPO is equal to a 40Ah SLA. When you consider the weight saving, it probably is. At my 100kg's, I envy the 50kg daughters who blast around using minimal power on their scoots. I look forward to soon riding a 30kg machine instead one that is 150kg. Once I get the brakes sorted out, I'll decide how fast to make it go.
