Hello, I'm new here.
Has anyone changed the set ups on conversion kits?
I have upgraded my 36v 500w conversion kit to a 48v 1000w kit.
It came with a twist throttle and pedal assist.
On my 36v kit, I changed the twist throttle to a thumb throttle and didn't connect the pedal assist, it all worked fine.
I have done the same with the 48v kit, but it isn't working.
As the brakes override the motor, I disconnected the brakes incase it was that, but it still didn't work.
I've changed some connections the same as I did on the 36v kit, so I am baffled to why doing the same to a 48v kit isn't working.
please can anyone help and advise.
Thank you.
Thank you.
