I posed a part of this question a while back in a thread about gearboxes. I've been searching high and low for a simple manual clutch that would be suitable for the power and torque ranges that we're working with on bicycles. This is for a gasoline powered bicycle, but I'm posting here because the motorbicycle forums have very little interest in this. Input is an unmodified 35cc honda four stroke. About the torque and hp of a well conditioned cyclist.
I've been to all of the industrial, sports, and lawn/garden clutch manufacturers pages and even telephoned some of them. There does not seem to exist a compact lightweight method of manually engaging and disengaging a low speed low torque drivetrain!!! Amazing.
For the sake of illustration, the ideal would be what is pictured below, but instead of freewheel cogs there would be a torque arm an an actuating lever with internal clutch plates.
What I'm aiming for is the elimination of the centrifugal clutch at the motor and placing the clutch at the crankset. I need a manually engageable sprocket on the crank. If it is impossible to source or design (i have all winter with a mill, tig welder, etc) such an item, then the next option would be to use a clutch/jackshaft at one stage removed from the crankset.
I looked at the internals of a coaster brake
and was beginning to think it might be possible to adapt a coaster brake hub to a jackshaft/clutch. Sprockets could be welded to the hub, inner race of the freewheel, or to the stationary collar of that the torque arm is attached to (now it would be rotating instead of stationary) but I just can't seem to wrap my head around how to accomplish this. Actuating arm would be welded to the original input sprocket (i think). There would need to still be some application of a torque arm, but where to put it? I need to get an old coaster brake and take it apart on my workbench.
Please Please PLEASE!!! You guys have to help me. If I can overcome this little obstacle I can really get moving on this project. Without some method of engaging the transmission at the crankset the design turns into a rat's nest of extra freewheels, belts, tensioners, etc, in order to put this together. The clutch simplifies everything.
