plug RCD trips houses RCD, why?
jimmyhackers
my father uses a plug RCD on his electric lawnmower.....when the RCD is switched off/unplugged, this trips the houses breaker.
what could be causeing this? a faulty plug RCD, bad house wiring?
note: i have a similar plug on my stick/arc welder and this causes no problems.
thanks in advance
jim
Does this in turn trigger the 'test' button to turn it off? Diverts a small amount of power from active to ground, causing an imbalance between active and neutral.
I think active is called HOT in the US?
