2fast2green
10 µW
- Joined
- May 16, 2013
- Messages
- 5
Hi guys
I have an eBike Polaris Vector, 2012 version not working due to a dead battery. I opened the battery and I found the BMS totally "cooked" ! The cells also are in bad condition.
The original battery is a 29,6 8S 6A lithium. I'd like to rebuild the battery with Sony Konion VTC4 2100 mAh 3,6 V, with an 8S5P configuration, 40 cells, I have a 28,8V 10.5Ah, probably the controller works fine also with nominal 0,8V less <> the original one.
The problem is the battery connector, it have 2 bigger connector for positive and negative, and 4 more little connectors, I don't know their function. Probably two are a battery-in-frame check, but the other 2 ? temperature sensor ? regen on/off ?
Two questions :
- the bike has a regen function, I need a special BMS to manage the current coming back to the battery ? I can disable this funcion cause I check it and the Wh coming back to the battery are near nothing !
- how I can manage the 4 little connector ?
Thank for your help.
Two questions :
