bobsyleck
1 W
I'm having very low torque issues with my 1000W 48V Rear Hub Motor (Kit), also it does not like moving off from a standing start (in fact sometimes/occasionally refuses), the motor is loud and juddery esp. attacking an incline, however once up to speed all is sweet!!
I have the Tester Unit (Lyen omnitester) which is telling me that hall sensors, phase wires, throttle etc. are all OK !! so I'm putting it down to either a blown MOSFET? - which I'm not sure I can test without removing? Or, it could be that my Lead Acid Batteries (new) aren't providing enough Amps for the initial take-off? (they're only 10Ahr each x4 in series)?
I added a third shunt as there was an empty space available (2 shunts already insitu), and I swapped out the 63v capacitors for some equivalent but better spec (100V, same 470uf) *Nichicon FW Series Audio Grade Electrolytic Capacitors 100V
I've used 10 gauge (6mm) wiring on my rig apart from where the final battery connects to the Controller, as the Controller feed wires are somewhat less capable than this (its just the way they come).
I'm looking for someone with more wisdom than I on these matters! I'd hoped to have solved any poor amperage issues with good caps 'n shunts and superior wiring (up to a point) but think maybe the Pb battery specs are simply not up to it? Or as I said earlier, perhaps a defunct MOSFET? (any one of twelve!!)
