Popstar
May 2013 update: I'm adding my 2nd build progress
1st Build: mxus folding bike
I’ve been riding this e-folder bike since August, but only now am getting around to making a build thread. I became interested in folding bikes and e-bikes after I moved into a house with a garage for the first time. My wife and I work at the same company campus and commute together, but she often gets stuck later than me, so having a folding bike in the trunk is a great way to avoid driving 2 cars or staying at work later than I need. On weekends, I will set out over the big set of hills into town and have made it 26 miles on 10ah with a bit of leg boost
I based many of my early decisions from RVD’s Dahon build: http://www.endless-sphere.com/forums/viewtopic.php?f=6&t=34958 .
Pieces (in order of installation)
2008 Dahon Speed D7 (Craigslist)
7 speed, Chromoly frame with v-brakes, 20” wheels
Rear dropout is ~130mm but can fit a hub motor with brute force
Be aware that there was a stem recall for 2008 Dahons. I got mine swapped for free at REI, per Dahon USA call center instructions
36V 12ah Headway battery ((BMSbattery, $405 including shipping and charger)
30-60A option, CNSFEDEX shipping, 240W charger
Geared MXUS kit (cellman, $290 w SAL shipping)
Built in 20” rim, high quality and very true
18A basic controller, thumb throttle with cruise, e-brakes, handlebar powers witch.
7speed 11t DNP freewheel had gear spacing issue that makes 6th gear skip every 4th tooth. Very annoying.
Sadly, cellman is not stocking these anymore. He told me a few months ago he would be offering a new e-assist motor in the "next few months"
Nord-lock washers (McMaster, $15)
These are great, and very important since the stretched dropouts would love to move the axle if these were not preventing it from loosening.
Schwalbe Marathon Racer HS 366 20” tires
Pumped up to 80psi with you eyes closed, you could trick yourself into thinking you were on a low-resistance road bike. (Tip: never close your eyes riding a folding bike!)
Harbor freight 11" X 7" X 4" “Aluminum” Case
This case is fancied up cardboard and aluminum strip, but it fits the headway cell perfectly with some padding and wood flooring samples (from home depot) for reinforcement and as screw in points for mounting to rack.
Recently I added a padlock by bending two door latch mounts 90° and JB WELD’ing them inside the box sticking out. It won’t stop a true thief, but makes it look legit.
Turnigy 130A Watt Meter (Hobbyking, $30)
The wide silicone wire on this thing does not fit well in Anderson connectors, which is very annoying.
Brooks Flyer (REI)
Enough is said about Brooks. They are are comfy. nuff said.
Mirrycle Bike Mirror
After riding down weaving country hill roads with this, I am surprised that bike mirrors are not more widely used by all bikes.
Shimano Mega 7 11-34T freewheel (bike co-op, $5!!!!!!)
I found this in the used grab-bin at a used LBS, and I went out and bought a lottery ticket afterwards. Compared to the DNP I was riding before, this thing makes the e-bike feel much lighter when not using throttle. The fact that my DNP had an unusable 6th cog adds to my excitement with the shimano. Now I can switch between the top 3 gears smoothly going up any hill.
Overall the bike has been a great experience learning bikes and how to utilize a garage workspace. The setup is as fast as I would want to go on a folding bike, about 18.5mph on flat with “for show” pedaling. Since it has cruise control, I keep the rear e-brake cutoff lever, but it is sad that these don’t at least come in v-brake compatible pull ratios!
2nd build planning
The folding dahon is great and serves its purpose of providing transport from the trunk of the car. Th eebike bug continues to nag me to build a full size ebike. Thus I am embarking soon on a e-bike build for my in-laws coming from china using a mid 90's Gary Fisher hardtail from craiglist. I am working with cellman to get some MACs and trying to see if his new 14S9P Samsung 18650 NCM triangle pack can fit my frame. The more I play with various e-bike parts and vendors, plus ES post reading, the more I realize that it is worthwhile to utilize sellers like cellman.
More to come in the coming weeks.
Brooks Flyer (REI)
2nd build planning
