ions82
I have a MAC 8T motor (black version) that I recently got from EM3EV.com I power it with a 12s3p LiPo battery. It's been a fantastic setup thus far. However, I believe I may have a problem in the Hall sensor circuit. Today, I was running a bit late for a meeting, so I was riding my bike pretty hard. It was only for a few minutes (meeting was only two miles away.) Everything seemed fine. When I left the meeting, I encountered a problem. The throttle just quit responding once I started off again. Then, it would sort of cut in and out. I rode around for a little bit and tried resetting everything. The motor also took to "growling" at me. I decided to start heading for home before things got any worse.
On the ride home, the system would seem to cut in and out. At times, it seemed like it was working fine but would cut out again. Does this sound like a bad Hall sensor or a bad wiring connection? The plugs that came with the system are pretty crappy. So, I'm wondering if that is the culprit. Or, is it more likely that there is a bad Hall sensor? I'm still new to the e-bike scene, so I just wanted to see if the magic of ES could help point me in the right direction before I go and start tearing things apart. Part of me thinks that the intermittent nature of the problem would point toward a bad wiring connection. Then again, I've been wrong plenty of times in the past. I'm just guessing. I have an e-bike motor tester, so I figured I could connect that thing to see what it says. If nothing else, testing the Hall sensors might help me better understand this whole thing. I'm really hoping that I don't have to replace Hall sensors. It sounds like a tedious job, and I really don't want to start throwing money away on internal combustion again. I have about $1,500 wrapped up into my e-bike, and I probably haven't even gotten 200 miles out of it!
