I thought obsessively today about LTO batteries, and I Was frustrated with the fact that they are able to be charged at such a high C rate, but that house service here in the states, even 240 services, can not reach the full potential of LTO quick charging. I Was racking my brain for ways to actually charge the batteries at home at a really high C rate, at the pack level. The following might be obvious to someone with more experience, but with my limited understanding of theory, I was not sure if it was even possible. (and I Do not plan on implementing this without having a much better grasp on it, assuming it's even possible. )
Would a battery to battery charger be feasible? I thought that I could have a larger capacity LTO bank at home that can be charged at a slower rate, and then used to rapid charge another pack. I Am aware that direct pack to pack wiring without the same AH and charge will lead to the packs attempting to equalize, so that is a no go. then I thought, could it be as simple as using diodes to prevent back flow, perhaps a Voltage regulator circuit to keep the Constant voltage / current, and perhaps a circuit to control the rate of discharge from the full pack?. a few ideas popped into my head, Like MPPT chargers for example. I assume that it IS possible and that it is just beyond me right now.
I know they make battery to battery chargers, but they seem to be for lead acid and like 12V to 36V. I am aware that LI batteries need to be charged in a more precise manner, and I am familiar with using meanwell chargers to charge packs with a cycle analyst. I Was thinking that as long as the pack that is being used to charge the other pack has a voltage and capacity high enough to provide CV and CC for the whole charge, with a high enough C rate to handle the rapid transfer... and that you developed a circuit to funnel in the juice within the parameters that It would be a go. thoughts?
