Possible to power headlights with the Bafang C965 / BBS02
staldor
HI
Have anyone tried to power some headlights with the BBS02 / C965 system? I guess some of the pins gives the display 5 volt or something, which should be enough for a led light. Question if the cords can deliver enough power.. Thought I should ask here before I try it out.
Thanks!
Yes, I was also thinking that the power would probably be pretty limiting. I'm therefor just thinking of using the battery with voltage converter. Would be nice though to control the lamp form the controller..
A buck down direct from the battery is a better idea. they can be obtained from ebay pretty cheaply. Might consider a fuse with it, just incase it shorts.
