LewTwo
I am looking at getting a new battery for my primary ebike. Before I do that I would really like to know how much power I use on a typical trip to the grocery store. I have, in the past, managed to 'magic smoke' a couple of those cheap watt hour meters. So I decided to make a DIY version. I was going base it on a Peacefair 0-100 volt 0-50 Amp PZEM-051 DC Power Meter but I got one of those and found out that the External Shunt is HUGE! Time to re-evaluate.
Known facts:
1 ) Neither of my ebikes draw more than 1200 watts from a 60 volt battery (closer to 1000 I think).
2 ) Number one means that I should not need more than a 20 Amp meter.
3 ) None of my chargers put out more than 5 Amps at 58.8 Volts.
4 ) I use XT60 on my ebikes except for the oddball Golden Motor 3.0 x 8.5mm barrel plug on the charger.
5 ) Peacefair makes a version of their DC Power Meter that is rated for 0-20 Amp at 0-100 Volts: PZEM-031
6 ) The meter retains accumulated values (watt hours) until reset.
7 ) The PZEM-031 uses a internal resistor that greatly simplifies the wiring required.
8 ) The PZEM-031 can be used between a charger and a battery or between a battery and load w/o rewiring.
9 ) The PZEM-031 is marketed by Drock, Hiletgo and others under their own brand names.
10) Available on-line documentation for the meter sucks.
11) I do not ride in the rain.
So this is what I have come up with:
Because I am lazy, I plan to use XT60 connectors pre-terminated with 150mm long 12 AWG stranded wire with silicone insulation. I am using XT60 Male connectors on both the input and output sides. Then all I need is a Female to Female XT60 adapter cable to plug it in-line with an XT60 power cable regardless of the Male/Female order. Of all the various XT60 adapters, a Female to Female does not seem to be one of them but 'tis simple enough to make. I also want a couple of 'raw' wire connectors for testing unterminated batteries or chargers or motors.
I have occasionally run into a system without a On/Off switch (my primary E-Bike for instance). I recently purchased a Jtron switch that is rated at 50 Amps at 50 Volts continuous but it has not been tested. I am going to stick it in there as well. Worst case scenario is I have to replace it with something else or remove it. Yes the switch really does read "NO" and "OFF" ... go figure.
This is NOT intended to be permanently installed but rather to be used as needed to acquire some desired information. I am thinking of putting some paracord loops through the sides to that it can be strapped or tie wrapped to a bike frame as needed.
Meter: https://www.amazon.com/dp/B079JVGRSL
Project Box: https://www.amazon.com/dp/product/B08214K51C
Switch: https://www.amazon.com/dp/product/B08612YVG9
Xt60 Cables: https://www.amazon.com/dp/B07CN2S53W
Wire: https://www.amazon.com/dp/B01ABOPMEI
Feel free to comment, tell me how badly I am screwing up, etc.
Lastly:
At 5:00 AM the temperature in Houston is 19 degrees fahrenheit ... damn but that is cold
Known facts:
Lastly:
