Hugh-Jassman
- Joined
- Jun 20, 2015
- Messages
- 407
I am still searching for appropriate sized narrow profile, low rpm motor that does not need a large gear reduction to the drive wheel, a one stage reduction will probably not be possible. And I know that not many people like the idea of a slow single speed e-bike. But for a heavy duty cargo bike it is the best way to go.
I think it will be absolutely necessary to build some kind of two speed gear box. So I have been thinking about this one that looks like maybe it could be printed in various parts.
Is it possible to print with hard enough materials like maybe epoxy of some sort?
Maybe print the original parts then mold them out of harder materials?
https://www.youtube.com/watch?v=kmJADKX5yaw&t=79s
[youtube]kmJADKX5yaw&t=79s[/youtube]
Some one should design a printable gear box with only two or three ratios, and put it out there on the internet for free, in-order to subvert the corporate ownership of information.
450lbs with 8 to 10% grades dictates at least a 750 watt nominal motor. And more than likely it will need to be called a 1000 watt just to get up around 1500 watts for the worst of the hills. Maybe I should just make a plaque with the right numbers on it to use a more powerful motor.
And I am stalled out at not finding a sprocket adapter that will fit onto the free-hub body behind a modified cassette, maybe 6 or 7 speeds.
for printable belt pulley: https://endless-sphere.com/forums/viewtopic.php?f=1&t=92388#p1351182
