Good afternoon gentlemen,
This is my first post here ( but not a first time visit)
Recently purchased a new:
- 52v 20Ah (14s 6p, INR 18650, 35E ) triangle battery
and
- cycle satiator 48v
My problem- simply put- is:
When i start charging, it goes for a while on steady current,
and little oscilating voltage,
but as it reaches +/- 53v,
The current goes down from- say- 2A to 0.2A,
and also begins oscilating ( 0.6 ,0.4, 0.2, 0.1A loop ).
By reaching roughly 80%, it stays on 0.2A most of the time,
and shortly after, i get: 'Pwr fault restart' screen,
and after a reset, few seconds of charging (oscilating 0.2A)
i get another power fault
I m using default 52 v, lithium, 100%, 2A satiator profile.
Strt trickle- 29.4v
End trickle- 41,2v
Bulk A. - 2A
End charge- 0.2A
but because of those 'Pwr' i was never able to charge that battery to 100%,
it stops on 78- 80% and faults begin to follow.
Battery has smart bluetooth bms so i can see all 14 s cell groups.
Difference between highest and lowest group is:
39.81v --> 39.75v ( only one- the last is that low )
the rest is within 39.79--> 39.81.
so i gather:
- the pack is not highly unbalanced
- is only two weeks since i received it- new
- the pack came at roughly: 29% capacity
- i tried to charge it at various currents (2A, 3A, 4A, 7A )
Current and Voltage oscilates
and round 80% numerous Power fault - no more charging...
I contacted charger vendor - they said, a cause might be:
- over protective BMS
- cells badly out of ballance
I' m still waiting for a reply from the battery vendor
Which is alresdy a couple of days
- so,
i do not really know what verdict could possibly come from their side,
I've bought that new battery to extent a bit my radius range,
and bought a satiator to avoid the worries about burnt house
or cheep charger failure- when i need it most,
but it looks at the moment that, in spite of investing in new, bigger pack
and far more advanced charger i'm still loading my old 48v battery,
with my old cheep charger.
If any of the members have been in similar situation,
knows the possible cause,
the solution to my problem,
or have some sugestions,
please share it with me,
before i'll be forced to buy one of those other chargers,
to simply check whether or not- i'll manage to reach full capacity with that..
Zibbie
Ps: should i - in the above mentioned scenario,
even attempt to try to load battery
To 100% with another charger ( if i had one)
and
Strt trickle- 29.4v
End trickle- 41,2v
Bulk A. - 2A
End charge- 0.2A
so i gather:
- so,
Zibbie
