Ch00paKabrA
Hi, I am finally into the final stages of my DH comp build. I bought an infineon 12 fet 4110 controller from EM3EV and need some help programming it.
I installed XPD and it is working. I did a test program at 10s because I had a 36v battery laying around and the xpd and controller interfaced fine and it ran.
I have just finished building a 98 cell 14s 7p battery using Samsung 18650 29E cells. 58v and around 20ah.
Here is the question. I am running a single MAC 6T at the moment (may upgrade to dual MACs later if needed) so what Amps should I set this up for? 20, 25, or 30. Here is what I want: I want to be able to cruise for a long time without over heating (in the summer as well). I think 40a might be too much from a heat stand point. There are some hills but there is only one that is fairly steep and long.
Second question. I have read that the phase amps can (should?) be significantly higher - perhaps 3 times the battery amps. So should I be running phase amps at between 75 to 90 amps depending on the suggested battery amps.
Thanks a lot. I am hoping to hear from some of you who know about this because I sure don't.
