PeteB
PeteB said:PeteB said:Chalo said:I don't want to bring bad news to the party, but the Crystalyte 53XX series motor is almost impossible to use effectively in a rear wheel format. The right side spoke bracing angle is nil; that's why I got a front 5305 as my first hub motor.
I would only use that motor in combination with a rim that has a lot of spoke hole offset, like the Surly Rabbit Hole. Otherwise you'll have to dish the wheel over to one side just to make it strong enough to ride on.
The motor I purchased is new laced on a rim.What is this Dish that you speak of?..Mounting the wheel more to one side? how would that make it stronger?
Hey Chalo.....You told me about a problem, Well sort of..You Don't want to answer my question?
Not to worry..I got this...
For any new guys that come across this post maybe via a google search...NOT to worry.. No bad news at the party.Just bad advise..There are MANY people here alone running a 5x rear hub successfully and Even on a Townie and if you come around some posting talking about dish here is your answer..
Sheldon Brown wrote
A bicycle wheel should have the rim centered directly in line with the frame. The fork ends are symmetrical with respect to the frame, and the hub axle locknuts (or equivalent surfaces) press against the insides of the dropouts.
Wheels should be built so that the rim is centered exactly between the axle ends on the hub. In the case of rear wheels, the spokes attach to flanges which are not symmetrical...the right flange is usually closer to the centerline than the left flange, to make room for the sprocket(s).
When rear wheels are built properly, the spokes on the right side are made tighter than those on the left side. This pulls the rim to the right, so that it is centered with respect to the axle (and to the frame.) Viewed edgewise, a rear wheel built this way resembles a dish, or bowl, since the left spokes form a broad cone, while the right spokes are nearly flat.
By extension, the term "dish" is used as a general synonym for accurate centering, even in the case of symmetrical wheels.
See also my Wheelbuilding article
