safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
I call it a "death spiral" because the small motor is so grossly overloaded on a steep hill with a tall gear that whether the throttle is full or partial it heats up and starts to smoke. All that "throttle fiddling" only works when you have a lot of power to begin with. If your motor can't even pull the bike up the hill when at peak power (in the higher rpms usually about 3/4 of the top speed) then as you slow down under the load things just get worse and worse. If I had 3 times the motor to draw upon then I could with "brute force" pass out of the low rpms and get back up to where the motor is "happy" and running cool.
That's why I've said time and time again that the "big power" solution is equivalent to having gears because if you have three times as much "good power" (high efficiency power) then you can get out of the "death spiral".
Imagine a 140 lb bike, a 185 lb rider, and only a 750 Watt motor... without a low gear you won't get up hills very easily and any PWM "effect" gets lost in the motor being overwhelmed with excessive load... the PWM "effect" does not save the bike from the "death spiral"...
The lower rpms get, the faster the heating... so trying to keep the speed up so as to avoid dropping into the "death zone" part of the powerband is important..
