bluovalguy
- Joined
- Dec 8, 2013
- Messages
- 40
Finally have put some miles on my bike since the weather has been nice. It's a Diamondback Edgewood 700c hybrid. Went with the rear drive 36v slow wind Q100 kit from elifebike. I hid a 3 speed switch on the bottom side of the controller box, and a switch on the side for cruise control. Set up a $14 watt meter which can be velcro'd to the seat post with the same anderson connectors between the battery/controller. I believe this controller is the KU65 equivalent, stock was 12a which was pretty weak. Soldering the shunt to 18a helped, but with a 40v Greenworks battery it was too slow... wouldn't go much over 18mph. Now am running with Ryobi power tool batteries in series, for 55v nominal/ 62v fully charged. With these 4 batteries it's basically a 15s 8ah 18650 pack (more details on the batteries linked below.) Tested briefly still at 18a and it ran great, but dialed it back to 14-15a for less strain on the motor.
Greenworks- http://endless-sphere.com/forums/viewtopic.php?f=14&t=55790
Ryobi- http://endless-sphere.com/forums/viewtopic.php?f=14&t=56505
This thing is a blast with the extra voltage. With the 3 speed switch on high it cruises at 25-27mph. It got up to 30 the other day with moderate pedaling and a tail wind. It feels like it's still providing assistance into the low-mid 30's going down hills. With the switch on mid it goes about 20-22 which is perfect most of the time... pulling 5-10 amps for a range of about 20 miles. Low speed is similar to running on the 40v batteries only, 17-19mph with a bit more range. It has enough torque to maintain about 15mph up moderate hills, but I have to pedal hard to keep 10mph up the really steep hills.
Has anyone else run this high of voltage reliably over time? I understand with this controller it should really be kept below 60v (63v caps), but I haven't had any problems with it yet. Also the motor seems pretty happy, it barely gets warm unless it's really bogged down for awhile. It doesn't seem to groan any worse up hills with the higher voltage, just faster. I will make sure to post back if anything blows up. I do have a spare controller/motor.
Just wanted to share my experience, since I was skeptical about the performance of the small geared motors. I didn't want a huge geared motor or direct drive for the stealth and weight issues, and this ended up working out well.
