Has anyone here tried the QS "motor assembly" as they call it?
Most stuff I've read is pretty positive about the mid-mounted QS motors, but wondered if anyone had any experience with the swing arm kit.
I'm looking at converting a vintage scooter - an NZeta (essentially a New Zealand assembled Cezeta) - and I reckon that this should fit in the frame, so would sort out the motor, swing arm and drive train in one fell swoop. Plus the NZeta runs on 12" wheels by default, so I can keep the front end basically stock.
Do you think that 100km/hr is a realistic expectation for this at 72V and with the Votol EM72150SP controller?
The scooter in original form is about 120kg (dry weight, I think). Obviously it's not terribly aerodynamic and that wouldn't change. I reckon this motor and swing arm are lighter than the original. Plus I won't have exhausts or fuel. I think it might come out about even or maybe even slightly lighter.
I'm considering using these batteries, which are available here in NZ
https://bluecars.nz/shop/new-53-ah-ncm-battery-module/. I think there's room to put 20 of these in series pretty low in the frame in front of the motor, which would be about 20kg and give me about 4KWh of capacity. Haven't worked out what the range would be exactly, but it's in the same ball park as the smaller capacity battery on the Cezeta 506. The battery spec sheets don't list the discharge stats, but I've got a query in to the retailer to make sure they would handle the 80A continuous and 150A peak current draw.
PS. First post. I’d been following this thread on the motor. Hopefully it’s ok to post this question here - hadn’t realised it was in the Motor Tech section. Can move to the E-Scooter and Motorcycle section if not
