andreworsmond21175@gmail.
100 µW
Hi all,
Im getting a QS273 40h 5T for my ebike and want to get the highest top speed possible for the motor with mad acceloration for as long as possible.
specs:
- battery- 91v full charge, 214 amps peak, 175 continious (safe)
- nucular 24f controller (has field weakening)
- rear wheel - 25 inch diameter (19 inch rim plus tire)
- baseline rpm for the QS273 5T (dont know)
- kv rating for the QS273 5T (dont know)
There are some bio's here with the same setup and guys are hitting pretty high top ends over 60 mph with this setup(happy to be wrong)
If anyone could provide any guidance on field weakening for my nucular to increase the rpm, how to setup the phase amps and the amps assigned for field weakening based on my battery output and v it will be much appreciated.
My current idea was to do the following settings:
- Speed Setting: 125%
- Battery Amps: 185
- Phase Amps: 320
- Field Weakening Amps: 50
Thank you for your time,
Andrew
specs:
- Battery Amps: 185
- Phase Amps: 320
Andrew
